Activity Forums Apple Final Cut Pro Legacy razor blade tool and the gap that remains
  • razor blade tool and the gap that remains
    Posted by Arthur Luhn on April 27, 2007 at 1:30 pm
    Hello,
    If I use the razor blade tool in the middle of a take or to tighten the flow between two scenes, a gap always results- how do I manipulate it so that any razor blade cut results in all the footage to the right of that cut, on the timeline, is automatically moved to the left to fill in the gap?
    Peter Dewit replied 19 years, 4 months ago 3 Members · 3 Replies
  • Tom Wolsky
    April 27, 2007 at 1:45 pm
    Instead of just lifting out a section which I assume you’re doing with the delete key. Use ripple delete by pressing shift-delete or the forward delete key on an extended keyboard.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Arthur Luhn
    April 27, 2007 at 3:25 pm
    Yes I was using just the delete key. Thank you very much.
  • Peter Dewit
    April 27, 2007 at 5:08 pm
    close gap or ripple delete works well but for the future you may want to try using the trim tools. it’s a bit more exact and won’t leave gaps.
