Activity Forums Adobe After Effects Ray-tracing GPU greyed out in After Effects
  • Ray-tracing GPU greyed out in After Effects
    Posted by Caroline Quinn on October 25, 2013 at 7:05 pm
    Hello all,
    I am not a computer whiz, so my technical vocabulary is limited, but I need help. Adobe After Effects kept crashing over the simplest tasks like moving an object. After some research I found that it might help if I were to switch the ‘Ray-tracing’ tab under After Effects> Preferences> Previews> GPU Information from CPU to GPU. However, the GPU option is greyed out, with an excerpt saying ‘(GPU not available – incompatible device or CUDA driver). I downloaded the newest NVIDIA CUDA driver, and it’s still greyed out. I tried the GPUSniffer in the terminal and it says ‘Did not find any devices that support GPU computation.’
    Under ‘OpenGL’ in After Effects GPU information it says,
    Vendor: Intel Inc.
    Device: Intel HD Graphics 4000 OpenGL Engine
    Version: 2.1 INTEL-8.16.74
    Total Memory: 1.38 GB
    I’m working with CS6 on a Mac Mini.
    Any ideas? Help!
    Alex Gerulaitis replied 12 years, 10 months ago 3 Members · 4 Replies
  • Alex Gerulaitis
    October 25, 2013 at 7:31 pm
    Mac Mini with its onboard Intel graphics is not compatible with GPU acceleration in AE, regretfully, and there isn’t much that can be done about it w/o changing the computer.
    — Alex Gerulaitis | Systems Engineer | DV411 – Los Angeles, CA
  • Todd Kopriva
    October 25, 2013 at 9:06 pm
    You must uninstall that.
    If you don’t have Nvidia CUDA hardware (which you don’t), you must not install Nvidia CUDA driver software. If you install a driver for a piece of hardware that you don’t have, you can badly confuse applications (like After Effects) into thinking that your computer has capabilities that it doesn’t. In this case, you can trigger a crash, since After Effects may try to call hardware that isn’t there.
    For details of how After Effects uses the GPU, see this page:
    https://blogs.adobe.com/aftereffects/2012/05/gpu-cuda-opengl-features-in-after-effects-cs6.html
    After Effects team blog
  • Todd Kopriva
    October 25, 2013 at 9:08 pm
    That’s not entirely true. It’s only true about the GPU acceleration of the ray-traced 3D renderer, which depends on CUDA.
    The OpenGL features work fine on the Intel GPUs.
    See this page for details:
  • Alex Gerulaitis
    October 25, 2013 at 9:11 pm
    [Todd Kopriva] “The OpenGL features work fine on the Intel GPUs.”
    Got it, thanks Todd.
