Activity Forums Compression Techniques RAW photo timelapse pixelation in vimeo
  • RAW photo timelapse pixelation in vimeo
    Posted by Sam Page on December 24, 2015 at 12:15 am
    Hey,
    Having problems getting the time-lapse in my vimeo video clean without blocking.
    https://vimeo.com/149840678
    I used adobe bridge with camera raw to colour correct then opened the photos as a raw sequence in After Effects where the project is 16 bit
    I have exported at Pro Res HQ and also used dynamic link to Premiere where I inserted the clip with the rest of my pro res HQ footage.
    I exported with H.264
    frame rate 25
    progressive
    square pixels
    profile: high
    Level
    5.2
    Render at max depth
    VBR 2 pass
    target bitrate 20
    max bitrate 300
    keyframe 1
    Render at maximum quality
    The footage is fine before vimeo but once I upload the time-lapse is pixelated with blocking??
    I know 8 bit is susceptible to this behaviour but these are 14-bit RAW photos from A7S.
    I used to own a 7D and never had this problem.
    Is it the camera or my workflow or compression error?
    I am a little stuck and wouldn’t mind some help.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Ivan Myles replied 10 years, 9 months ago 2 Members · 1 Reply
  • Ivan Myles
    December 24, 2015 at 5:53 am
    Looks fine on my phone. Where are you seeing the issues? First, download the Vimeo transcoded file and view frame by frame through the problem areas to be sure there is an encoding issue and not just a streaming bandwidth issue when viewing online. Second, if there is an encoding issue, consider increasing the number of frames between quick cuts, and reducing/slowing some of the motion. High compression encoding works by reusing pixel blocks from frame to frame. That can produce poor results when there is too much motion and too many quick cuts.
