Activity Forums Adobe After Effects raw keyframe data?
  • raw keyframe data?
    Posted by Alex Weil on July 10, 2018 at 8:52 pm
    Hey,
    i searched the web and this forum for hours, but the only thing i could find was a post from 2010:
    https://forums.creativecow.net/thread/2/977043
    maybe something changed in the past 8 years.
    is there a way to get the raw keyframe data into a textfile, copy pasting it doesn’t give me the ease values. maybe there is a script, plugin, whatever somewhere out there to get these informations?
    cheers
    Alex
    Alex Weil replied 8 years, 1 month ago 3 Members · 3 Replies
  • Kalleheikki Kannisto
    July 11, 2018 at 7:16 am
    There are a couple of keyframe-copy scripts on AEScripts, notably Easecopy and Paste Multiple Keyframes. I don’t know how they are storing the copied keyframe information, but you could ask the authors if they can be used for this purpose.
    Senior Graphic Designer
  • Steve Bentley
    July 12, 2018 at 11:10 pm
    Re: the OP and the way-back-when post.
    If you add an expression to the animated attribute but just let the default expression stay, then select all the keyframes and right click on one of them and choose “keyframe assistant”, then choose “convert expression to keyframes”, you will get keyframes for every frame, select them all (they are usually already selected at this point). Hit copy – because its all keyframes it will include the easing data.
    Then that can be pasted to Word or Excel and parsed to columns of data.
    Sometimes you have to let Word do some search and replace to convert double spaces to comma’s etc so you have a comma, or space, or tab delimited table of values that Excel will like.
  • Alex Weil
    July 13, 2018 at 10:48 am
    Thanks Kalleheikki and Steve for your replys.
    @ Kalleheikki: i contacted Mike from EaseCopy and he helped me out a littlebit with a reference to https://docs.aenhancers.com/ maybe i can get a script running that does the job for me.
    @steve: i think thats a way to get hardcoded keyframedata but that takes all my possibilities away to individualise the keyframes afterwards.
