Activity › Forums › Apple Final Cut Pro Legacy › Raw Image Types from a 50D Cannon
  • Shane Ross
    August 20, 2013 at 10:14 pm
    You don’t. FCP7 doesn’t work with the RAW format (H.264) that the camera shoots. It might LOOK like it will, but in the long run, it won’t. So you need to convert the footage to ProRes first. And you can’t use the internal FCP tool called LOG AND TRANSFER as it doesn’t work with that particular Canon. You’ll need to use Compressor, or MPEG STREAMCLIP, or 5DtoRGB.
    Shane
    Little Frog Post
