Activity › Forums › Adobe Premiere Pro › Raw green screen footage has frame drops / stutter
  • Raw green screen footage has frame drops / stutter
    Posted by Arif Mitha on August 16, 2018 at 9:37 am
    Hello, I am having an issue where if I import raw green screen footage into premiere I have a horrible stutter or lag in the video. I have tried all of the following solutions so far:
    Memory setting
    Reducing video playback quality
    Turning off FX
    Changing the project settings
    Changing Mercury
    Changing the sequence settings
    Rendering the sequence
    All of these did not help resolve the issue, and this is happening regardless of what camera I use. I just tried it with 4 different cams and the stutter exists in all of them inside Premiere.
    Arif Mitha replied 8 years, 1 month ago 4 Members · 6 Replies
  • Daniel Waldron
    August 16, 2018 at 4:07 pm
    What are the footage specs and what are your computer specs?
  • Arif Mitha
    August 16, 2018 at 10:47 pm
    MIR (Gaming PC)
    Corsair Graphite Series Black 730T Full Tower Case
    MSI X99S SLI PLUS ATX DDR4 NA
    Intel Core i7-5930K Haswell-E 6-Core
    G.SKILL Ripjaws 4 series 32GB DDR4
    ASUS GTX980 GPU
    Corsair Hydro Series H110 Liquid cooler
    Toshiba 3.5-Inch 2TB 7200 RPM HDD
    Corsair AX860i Modular 80 PLUS Platinum PSU
    2x SanDisk Ultra II 240GB
    Monitors: 3 27″ BenQ GW2760S
    Sputnik (Streaming PC)
    Footage running off an SSD
    Footage specs:
    i attached a pic of the video stats, idk why it says 1k FPS it was recorded at 60
  • John Pale
    August 17, 2018 at 12:04 am
    Something is messed up with the metadata in he file. You need to tell Premiere not to pay attention to it.
    Right click the clip in the Project window.
    Select “Interpret Footage”.
    Change it to 60fps, or 59.94 fps (Thats more common).
    See if it plays better.
  • Daniel Waldron
    August 17, 2018 at 1:19 pm
    I would also convert your footage to DNxHD or ProRes, which is easier for Premiere to handle.
  • Jeff Pulera
    August 17, 2018 at 3:43 pm
    Premiere doesn’t care if your footage is of a green screen or is regular video, so being green is irrelevant to the playback issue. Rather, please tell us what is the footage? What kind of clips from what camera?
    As mentioned, the 1000fps thing is bizarre, so tell how the footage originated and that will help us to help you.
    Jeff
    Jeff Pulera
    Safe Harbor Computers
  • Arif Mitha
    August 18, 2018 at 2:04 am
    ok sure thing.
    I am making a video comparing logitech webcams, I recorded footage of me infront of my GS for each camera, the videos were recorded using Open Broadcast Software, at a 10k bit rate, 1080p 60 fps, setting. I also recorded some other footage using a Canon R700 camcorder in the exact same spot.
    The files were recorded using MKV and then remuxed to Mp4. If i key out the green screen in obs before recording the footage plays fine in premiere. But if i leave the GS in, the videos lag in playback.
    The clips are all of me sitting in a chair and just talking. Nothing complex, and the room is well lit.
