Activity Forums VEGAS Pro Raw DV
  • Raw DV
    Posted by Braedon Bryers on August 28, 2009 at 1:56 am
    Hi i use Sony Vegas alot and was wondering if there is any way of changing the setting of importing from a dvd to Raw DV?
    at the moment it’s importing to mpeg2….i want to change it to import to Raw DV
    thanks
    Mike Kujbida replied 17 years ago 3 Members · 4 Replies
  • Mike Kujbida
    August 28, 2009 at 5:29 am
    Sorry but no.
    When you import something, you get it in it’s original format.
    If you want DV-AVI (raw DV), you’ll have to render to that after importing.
  • Braedon Bryers
    August 28, 2009 at 3:00 pm
    thing is it rip’s ot to mpeg and is compressed….was looking more for an easier way then capturing in real time via a capture card
  • Mike Fields
    September 3, 2009 at 2:51 am
    You will have to convert it to DV if that is what you want after you import from the DVD. DVD’s video files (.VOB) are mpeg2 already – that is the format of a DVD. Using some sort of “capture” of the video from a DVD player is not going to get you any better quality than what you can get by grabbing the data from the DVD (mpeg2) and editing that into whatever format you need (although, any conversion between compressed formats usually results in lost quality)
    mikey
    You can’t have too much disk space or too many gadgets !!
  • Mike Kujbida
    September 3, 2009 at 9:57 am
    [braedon bryers] “was looking more for an easier way then capturing in real time via a capture card”
    File – Import – DVD Camcorder Disc.
    As long as it’s not a commercial DVD, this works great.
