Activity Forums Adobe After Effects ratio check
  • ratio check
    Posted by Fred on June 5, 2007 at 2:18 pm
    just double checking.
    I was given an animation project from Flash with a document size of 864 x 540. They want a 4:3 video.
    I assume flash works with Square Pixels.
    I export a quicktime from flash at 864 x 540.
    I place the 864 x 540 quicktime file into a 720 x 486 After Effects comp.
    I scale the 864 x 540 quicktime file to 90% inside the 720 x 486 AE comp.
    I render out and use the 720 x 486 AE comp in Final Cut Pro.
    thus
    I get a 720 x 486 4:3 video with the “correct” dimensions of the original graphic artwork that will display correctly on SD NTSC TV.
    That sound right?
    They also said they might want it widescreen. which I would assume would be the 16:9 1280x 720. I know these are the wrong dimensions, but that’s what they created the artwork at. I can export from flash at any size, then squish or crop in After Effects. Any suggestions?
    -Thanks Y’all
    Sam Moulton replied 19 years, 3 months ago 3 Members · 4 Replies
  • Steve Roberts
    June 5, 2007 at 2:40 pm
    Drag the 864×540 QT into a 720×540 comp. You can either letterbox the video or chop off the sides. You generally don’t want to squeeze it (to fit) and thus distort it. To letterbox the video, use the “fit to width” shortcut, ctrl+alt+shift+H on Windows, cmd+opt+shift+H on Mac.
    To render, drag the 720×540 comp into a 720×486 (or 480) *preset* comp and render that.
    If they want it widescreen, drag the QT into an 864×486 square pixel comp. You’ll have to let the top and bottom be chopped off, or show black bars on either side. This is called “pillarboxing”, and is not as well accepted as letterboxing.
    To render, drag the 864×486 comp into a D1 or DV widescreen *preset* comp. If you use DV (480), let the top and bottom 3 pixels go offscreen. (If you had interlaced sources, you’d have to bump the comp up one pixel, but that’s not the case here.)
  • Fred
    June 5, 2007 at 5:14 pm
    thanks steve,
    got a question about precomping 540 layers in After Effects:
    If my Quicktime movie is 864 x 540, do I have to pre-comp the QT movie in a 720 x 540 comp?
    Can’t I just drag the 864 x 540 movie into a NTSC D1, 720 x 486 After Effects Comp, and scale it down to 90% even, letting the sides be chopped off.
    Isn’t that doing the same thing as the 720 x 540 Pre-Comp Fit. You’re scaling the 540 Pre-comp to 90% as well.
    They both look the same when I A/B compare them.
    Is that ok?
  • Steve Roberts
    June 5, 2007 at 6:29 pm
    Yes you can, as long as you use the D1 720×486 comp preset.
  • Sam Moulton
    June 6, 2007 at 1:33 am
    864 X 540 is a weird picture ratio. Doesn’t make 4:3, doesn’t make 16:9
    It does make 8:5 which is a long way from 4:3. You’ll end up with 72 pixel wide bars on either side of the comp if you keep full height because 720 X 540 is 4:3
    If you don’t want the black bars you need to fit to width which crops off the top and bottom. You can either do this in a 720 X 540 comp or by dragging your SQ pixel Flash QT into a D1 comp and fitting horizontally. Make sure the X and Y scale values are the same and you are good to go for render
