Activity Forums Apple Final Cut Pro Legacy Rather URGENT question on exporting a file to work in Window Media Player
  • Rather URGENT question on exporting a file to work in Window Media Player
    Posted by Jeff Newton on April 11, 2006 at 6:01 pm
    I am sorry that my questions are usually urgent….
    My client wants to stream the video that we just completed on their site (that goes live tomorrow…hence the urgency) but they want to give a quicktime/windows media player option. I opened the file in quicktime and selected the export option and saved it as an AVI file but to no avail.
    It exported the file and created an independant file but when I tried to open it in WMP it said that it was the wrong file format.
    Is it the codec? Do I need to go somewhere and download the codec or can someone think of anything else?
    Thank you, Jeff.
    Jeff Newton
    https://www.jeffnewton.com
    John replied 20 years, 5 months ago 7 Members · 11 Replies
  • 11 Replies
  • Steve Connor
    April 11, 2006 at 6:11 pm
    You can always export an Mpeg 1 from compressor, that will work in QuickTime and in WMP!
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Debe
    You need an app that will convert to WMV, like Popwire’s WMV Component or Flip4Mac.
    Popwire is less expensive, but F4M has more options. Head-to-head comparisons show no real huge difference in quality between the two at default settings. If all you need is to convert to WMV, then Popwire is probably enough. If you think you’ll need more options, then Flip4Mac is probably your best bet.
    debe
  • David Bogie
    April 11, 2006 at 6:13 pm
    popwire or flip4mac from telestream
    These are QT export components, not free. You can google them or search here, the question comes up daily. Depedning on your machine and settings, exporting via Compressor to WMP can be a 6-to-1 ratio so you’ll need lots of time.
    Look, I hate to be the bearer of bad news, but your best bet is to find someone who understands their needs and can deliver in the time constraints, which are totally absurd. If you do not understand the process of providing the correct image formats and bitrates and can talk to their webhead in his/her language, you’re dead. If your client doesn’t understand bandwidth, lowest common denominators, target machines and the trade offs between image quality and file size, you’re just as dead.
    Hire it done.
    bogiesan
  • Ed Dooley
    April 11, 2006 at 8:20 pm
    And also make sure you know what they mean when they say “stream”. True streaming video will
    not work on a regular everyday http web site, it needs to be on a streaming server. If what they/you
    mean is that the video will play after enough of it is buffered, then that’s progressive download video.
    The WMV *and* QT route is a good one.
    Ed
  • David Bogie
    April 11, 2006 at 8:36 pm
    [Ed] “The WMV *and* QT route is a good one.”
    We’re hearing more an more on all of the forums about folks using only Flash video on Websites. “Everyone has Flash” and “the quality is acceptable” seem to be the mantras. Our encoding experiments with Flash video are less than encouraging but to be able to mount only one version of our videos is enticing.
    bogiesan
  • Ian Ian
    April 11, 2006 at 9:53 pm
    Just bought the flip4mac studio package and it didn’t do the trick for me. you can’t adjust anything and the wmv file turned out huge! A 4 min. film took over an hour to come out and looked terrible. So in the end I exported the films to video tape, went to a friend with a PC imported the films in windows movie maker and exported them as WMV files which was a matter of minutes. So safe yourself a lot of troubles and headaches and find a friend with a Windows PC
  • Debe
    April 12, 2006 at 2:36 am
    Ian-
    I’m not an experienced F4M user, but I KNOW you can make all kinds of adjustments in your compression in F4M. I’ve watched a client do it on his copy of F4M.
    You must’ve missed an option button somewhere.
    Go back and look again, or perhaps an experienced F4M user will point you in the right direction.
    debe
  • Jeff Newton
    April 12, 2006 at 5:01 am
    thanks guys for the help..I ended up purchasing the $30 program from Popwire and it worked great…thank you so much…you guys helped me make my deadline.
    jeff.
    Jeff Newton
  • Jeff Newton
    April 12, 2006 at 5:04 am
    thats actually an interesting idea…would I be able to import my quicktime/windows media player file directly into Flash and convert it. Flash is the one freakin’ program that thought would be awesome to learn but never had a chance.
    thanks, Jeff.
    Jeff Newton
  • Jeff Newton
    April 12, 2006 at 5:08 am
    after going to both sites I decided that it looked like popwire was the best..the description on flips site seemed wrong for some reason…I paid the $30 for the Popwire WMV9 export and it worked great…exactly what I was looking for…
    Jeff.
    Jeff Newton
