Activity › Forums › AJA Video Systems › Rather Urgent: Kona 2 and HDV set up.
  • Rather Urgent: Kona 2 and HDV set up.
    Posted by Craig Meadows on November 10, 2005 at 4:00 pm
    Working on a project shot on Sony Z1U HDV camera in HDV 1080i/50i.
    Have Kona-2, FCP5HD, SATA Raid, HD Monitors, and AJA HD10A analog to component HD converter if needed.
    Final product will be NTSC SD.
    Camera is video source for Kona-2…So should I use the firewire or HD analong outs using converter?
    What should my FCP easy set up be? …and how should I configure the Kona-2 control panel for this particular project?
    Any workflow tips greatly appreciated…thanks!
    Alexander Serpico replied 20 years, 10 months ago 4 Members · 4 Replies
  • Christopher Karcher
    November 10, 2005 at 5:49 pm
    I can walk you through the process as I have done this many times. IT’s easier to discuss…email your contact info and I’ll give you a call.
  • Craig Meadows
    November 10, 2005 at 5:54 pm
    Hey Christopher, thanks for the help. Your email info isn’t on your profile so I don’t mind leaving the company info. here:
    Craig Meadows
    Florida Production Group
    Pensacola, FL
    850-474-6566
  • David Battistella
    November 10, 2005 at 6:39 pm
  • Alexander Serpico
    November 14, 2005 at 8:22 pm
    Just went through this debacle this weekend.
    HDV is sluggish and a bit of pain in general…
    Rendering takes almost three times as longer than DVCPROHD.
    However, i must say it doesn’t look terrible and it plays out through the Kona pretty well.
    When finished cutting we laid it out in real time to HDCAM, easy.
    I never could figure out how to edit back to HDV tape tho… (not like i needed too, but that was annoying)
    Looking back, id like not to have to work in that format again in the future (unless it gets converted/new master tapes prior to editing).
