Activity Forums Adobe Premiere Pro Rate changed audio clip has echo when Maintain Audio Pitch is selected
  • Rate changed audio clip has echo when Maintain Audio Pitch is selected
    Posted by Dustin Parsons on July 3, 2014 at 9:39 pm
    So I’ve had to speed up a few voice-over clips to match the timing of an animation. To mitigate the chipmunk sound I figured I could simply choose to Maintain Audio Pitch in the Clip Speed / Duration window. The effect works in that the VO sounds much closer to the original, unfortunately it also adds a robotic echo.
    I tried sending the project to render in Audition after making the rate change and checking Maintain Audio Pitch in PPro but that did not fix the problem.
    Any ideas on a faster way to maintain audio pitch than manually pitch shifting each clip depending on the rate changed?
    Ashley Smith replied 10 years, 11 months ago 2 Members · 1 Reply
