Rasterize Pre-Comp
I’ve got some vector images that are set to Continuously Rasterize in a Pre-Comp. In order to keep the rasterization I collapsed transformations. The Pre-comp is in the comp three times and when I collapse trans two of the three disappear (actually they leave a small chunk in the wrong spot)
The vector images are masked twice, once for showing only a segment and once for the Write On effect to take place.
Any help? Thanks a lot!
