Activity Forums Adobe After Effects Rapidly show text word by word
  • Rapidly show text word by word
    Posted by Andrew Fed on January 10, 2022 at 9:58 pm
    Hi, guys. I wonder if there’s a way (expression – 3d party plugin – extension – some way) to accomplish what I must but without a lot of effort. I have a text – just a thousand of a single theme words written in a column. I need them al appear one by one in the centre of the screen in my video. Rapidly. Like 5 words per second. The most obvious yet clumsy way to do it is making a thousand layers with those words and then kill myself with opacity keyframes. But is there a simpler way to achieve that? I feel the answer is out there somewhere but I just cannot find it myself…
    Andrew Fed replied 4 years, 7 months ago 2 Members · 2 Replies
  • Kevin Camp
    January 10, 2022 at 11:10 pm
    From what you describe, it sounds like you have a list of words in a text layer, where each word is separated by a return (i.e. each word is on it’s own line). If so an expression on the source text could probably work for you, try this:
    Twirl down the text layer’s properties to get to Text>Source Text and enable expressions for Source Text (select the Source Text property and choose Animation>Add Expression). Then add this as the expression:
    lines = value.split('\r') ;
    rate = 5 ; // lines per second
    n = Math.floor( time * rate ) ;
    lines[n]
    It should animate thru each word at a rate of 5 words per second. If needed you can edit the ‘rate’ value in the expression, ex: rate = 10 would be 10 words per second.
  • Andrew Fed
    January 11, 2022 at 11:47 am
    Thank you so much, exactly what I needed🧐
