Activity › Forums › Apple Final Cut Pro › range with color correction
  • range with color correction
    Posted by Craig Alan on February 21, 2014 at 1:52 am
    I tried setting a range within a clip on the timeline. But when I color corrected in the inspector the render bar indicated that the entire clip was being adjusted. How do I color correct a selected range?
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
    Craig Alan replied 12 years, 7 months ago 3 Members · 5 Replies
  • Bret Williams
    February 21, 2014 at 3:20 am
    You can’t. You could slice it up and apply the correction to the resulting clip.
  • Craig Alan
    February 21, 2014 at 3:30 am
    I was afraid of that. Never had to do this before but we shot a musical performed live and the stage lights kept changing and not all video friendly. We can blade it up but I’m surprised that you can’t select a range and adjust audio or color what ever. Thanks.
  • Bret Williams
    February 21, 2014 at 3:52 am
    I’ve never heard of an app color correcting a range. I think what you’re looking for is keyframing. But sadly that hasn’t been implemented. Hopefully someday.
  • John Fishback
    February 21, 2014 at 6:23 pm
    You might be able to make an effect in Motion where you can publish selected keyframes. That might let you keyframe certain parameters across a c;ip.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Craig Alan
    February 22, 2014 at 12:27 am
    Thanks. I could see where easing in and out of a correction would make it more natural looking bout can’t see the downside to allowing any modification to apply to a selection. For now, we’ll blade it up as needed.
