Activity › Forums › Avid Media Composer › range specified for Dup is outside range of component
  • range specified for Dup is outside range of component
    Posted by Liam Stephens on April 5, 2006 at 1:58 am
    I have one scene from movie that has problems exporting to OMF. When i try to export to omf the error message “range specified for Dup is outside range of component” any ideas how to fix it. I’m on a G5 using Xpress Pro.
    cheers
    L
    Geraint Pari huws replied 20 years, 6 months ago 2 Members · 1 Reply
  • Geraint Pari huws
    April 5, 2006 at 4:39 pm
    Dodgy mix probably, make a copy and try the omf, if it works then keep splitting the origional seq till you figure out which effect is creating the problem and either remove it or adjust it untill the error goes away…
