Activity Forums Adobe After Effects Range selectors (stop speed variation?)
  • Range selectors (stop speed variation?)
    Posted by Chris Law on May 4, 2013 at 2:33 pm
    Hi, im animating text with range selectors and Im just wondering, is there anyway to make it so no matter how many letters in a word, they all animate at the same a speed, because theres a variation when u have a short word and then a longer one after.
    Kevin Camp replied 13 years, 4 months ago 2 Members · 1 Reply
  • Kevin Camp
    May 6, 2013 at 4:30 pm
    you could do this with expressions….
    first, in the range selector>advanced settings set the units to ‘index’.
    then select the end value and choose animation>add expression and add this expression to the expression field:
    text.sourceText.length;
    this will set the end value to be the number of characters in the layer’s source text no matter what you type.
    now, add this expression to the offset property:
    rate = 5; // characters per second
    (time – inPoint) * rate
    this expression simply takes the current time (in seconds), adjusts for the layer’s in-point and multiplies that by a rate that you can set.
    you can adjust the layer’s in-point to adjust the start time of the effect-on. if for some reason that won’t work for you, there are other ways to set the timing.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
