Activity › Forums › Maxon Cinema 4D › RANGE OF VIDEO
RANGE OF VIDEO
Posted by Dave Tavernier on October 6, 2005 at 6:55 pmI have a cube object with sides seoerated. the cube will rotate and as it does I have video on each side of the cube. I need the video to change at certain keyframes, How do I stop one video and start another video on the same face as the cube spins so that as one reveloution completes a new video appears? I hope this makes sense!
TIA!Ramón Ramirez replied 10 years, 5 months ago 3 Members · 7 Replies -
Brian Jones
October 7, 2005 at 12:00 amYou can keyframe the Material slot of the Material Tag. Each video is it’s own material, you just keep changing the material when you want.
Dave Tavernier
October 7, 2005 at 5:00 pmAnyone understand what Brian is suggesting? Please respond,
Dave -
Brian Jones
October 7, 2005 at 9:31 pmSorry guys.
Click on the Texture tag
Check out the Attribute Manager there should be a field called Material which has the current material you placed on the object. That material can be changed and keyframed. Since a video material is just a material with a video in it, you don’t have to change the video in the material you just change the material on the object using the texture tag.Assuming you are using a version newer than 7 you just right-click on the word material and choose Add Keyframe in the contextual menu that pops up. The little dot to the left of the word Material should turn red to indicated this value has been keyframed.
The only problem is that it, by default, it morphs between the two textures so if you want one texture to hold you just have to place keyframes to hold the material until you need to change it
Check out this example using simple textures. It only morphs when rendered though (do a Preview) not in the editor so don’t be fooled just scrubbing through the timeline…
https://members.shaw.ca/bdjones/MaterialSwap.c4d.zip
Dave Tavernier
October 10, 2005 at 2:14 pmBrian,
This is a great solution and everything works as you say but I don’t see the keyframes I have added in the timeline window……what am I missing? And how do you add a hold keframe? -
Brian Jones
October 10, 2005 at 3:29 pmYou have to go to the Timeline window’s Filter menu and choose ‘Show Animated Objects’ from the top group there. That will get your texture Tag keyframes to show.
Ramón Ramirez
March 29, 2016 at 9:51 pmHi Brian
Thank you for your answer. I had been hours searching for how to put image and video in a single object.
