Activity Forums Adobe After Effects Expressions Range control by slider
  • Range control by slider
    Posted by Pavol Feješ on May 8, 2017 at 1:50 pm
    Hi guys
    I’m trying to find a way to define a range for calculating the maximum value using the slider. I have 3 layers to calculate and 1 layer that this calculation affects. Slider ranges from 1-3. If slider = 3, the layer value is the maximum z (n1, n2, n3). If slider = 2, the layer value is the maximum z (n1, n2). If the slider = 1, the layer value is the maximum z (n1). I do not know how to define the range of these values for the calculation. Does anyone have an idea?
    Thank you very much for your answers
    n1=thisComp.layer("01").sourceRectAtTime().width;
    n2=thisComp.layer("02").sourceRectAtTime().width;
    n3=thisComp.layer("03").sourceRectAtTime().width;
    max = Math.max(n1,n2,n3);
    Steve Sierra replied 9 years, 3 months ago 2 Members · 3 Replies
  • Steve Sierra
    May 8, 2017 at 2:05 pm
    You can put this in your property :
    n1=thisComp.layer(“01”).sourceRectAtTime().width;
    n2=thisComp.layer(“02”).sourceRectAtTime().width;
    n3=thisComp.layer(“03”).sourceRectAtTime().width;
    s = effect(“Slider Control”)(“Slider”);
    if(s<33){
    }else{
    if(s>33 && s<66){
    max = Math.max(n1,n2);
    }else{
    max = Math.max(n1);
    Hope this works for you !
  • Pavol Feješ
    May 8, 2017 at 2:44 pm
    thank you Steve. but this was just an example. In fact, those layers are 44.
  • Steve Sierra
    May 8, 2017 at 3:12 pm
    I see…
    I’ll look into it, but it seems a bit complicated for me.
    I’ll keep you posted !
    Good luck 😉
