Activity › Forums › Adobe After Effects › Randomly arrange frames
Posted by Ron Dangus on January 3, 2011 at 5:16 pmHello,
I’m trying to make a movie of several thousands of pictures, each picture one frame. Right now it’s very structured, with different categories and kinds of pictures following each other. Is there a way to randomly arrange frames?
Thanks a lot,
RonRon Dangus replied 15 years, 8 months ago 3 Members · 3 Replies -
Todd Kopriva
January 3, 2011 at 5:29 pmIf all of the image frames are on a single layer, then you could apply time-remapping to the layer and then use a random number expression on the Time Remap property to play the frames in a random order.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Roland R. kahlenberg
January 3, 2011 at 6:06 pmHere’s a gem from Dan Ebberts –
If you want random pics at random intervals, this would
be one way:Import your pics into a comp and sequence them (let’s
say one second duration for each).Select all the pics and pre-comp them (move all
attributes..)Enable time-remapping for the new pre-comp
Alt-click (Opt-click) on the time-remapping stopwatch to
enable expressions.Paste in this expression:
n=4; //number of stills
seg_start_time = 0; //initial conditions
seg_end_time = 0;
i =1;
tmin = .5; //minimum cycle time
tmax = 2; //maximum cycle time
while (time >= seg_end_time){
i = i+1; seed_random(i,true);
seg_start_time = seg_end_time;
seg_end_time = seg_end_time + random(tmin,tmax);
Math.floor(random(0,n)) + .5;Edit the expression so that n = your number of pics, and
tmin and tmax are the minimum and maximum times you want
one pic on the screen.Good luck!
Dan
——–HTH
RoRKAE Training in South East Asia. AE templates for sale and rental. Click here for more
Ron Dangus
January 9, 2011 at 1:18 pmThanks,
So, if I have 6421 pictures, and I want them all to show once for just a frame, it’ll be:
n=6421;
seg_end_time = 0;
i =1;
Math.floor(random(0,n)) + .5;Is this it?
