Activity Forums Adobe After Effects Expressions randomly applied opacity with a range
  • randomly applied opacity with a range
    Posted by Jason Jantzen on January 21, 2013 at 8:28 pm
    I know of one who probably looks at this like child’s play (Dan), but to me, the issues is confusing as all get up.
    I have 100’s of layers and need an opacity value applied randomly to each one. The range is 33% 65% 75% and 100%. My math is pretty rusty, but I was just thinking that more than 2 numbers isn’t a range anymore, is it? Anyway, I would very much appreciate some help on this one.
    Jason Jantzen
    vimeo.com/jasonj
    Jason Jantzen replied 13 years, 7 months ago 3 Members · 5 Replies
  • Kevin Camp
    January 21, 2013 at 8:47 pm
    just a few questions….
    first, do you want a given layer’s opacity to animate randomly between those values, or just randomly set the opacity to a value between those values (so it sets it to say 33% and it stays that way though out).
    second, do you just want the opacity to be set to one of those 4 values, or can it be set to values between those values (like 40% since that’s between 33-65%). i assume it’s one of those four values, but i wasn’t clear on that…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jason Jantzen
    January 21, 2013 at 9:00 pm
    I want the opacity to stay the same throughout the comp, no random animation.
    and if it’s possible, make the opacity value one of those 4 values, but of course random from one layer to the next, and no in between values like 40%. This is a request from a Microsoft client if that gives you any idea how weird the request is.
    Thanks Kevin!
    Jason Jantzen
    vimeo.com/jasonj
  • Dan Ebberts
    January 21, 2013 at 9:14 pm
    An opacity expression like this should work:
    choices = [33,65,75,100];
    seedRandom(index,true);
    choices[Math.floor(random(choices.length))]
    You can apply it to one layer, select the Opacity property then
    Edit > Copy Expression Only
    select all the other layers
    Edit > Paste
    Dan
  • Kevin Camp
    January 21, 2013 at 9:15 pm
    try this
    vals = [33,65,75,100];
    r = Math.floor(random(0,3.999));
    vals[r]
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jason Jantzen
    January 21, 2013 at 9:24 pm
    thanks guys, both work perfectly. I’m sort of not surprised that nobody’s asked to do something like this. it’s always blinking, flickering, or some other animation.
    this saves me a TON of time!
    Jason Jantzen
    vimeo.com/jasonj
