randomized motion path with given start and end position
Alright, it’s been a frustrating day and I’m not getting anywhere at the moment. So I’m putting this third thread out here in the hope that someone smarter than me can get me started or let me know how to do this.
I have a slim vertical composition – similar to a vertically held smartphone.
I’m trying to create a randomised move with an element starting out of view below the bottom of the comp moving in a randomised slight arc out of view at the top of the frame and then start again out of view at the bottom of the comp moving back up with a slightly different arc. I also want to be able to control the duration/speed of the movement (overall) just as Dan does with the Min and Max segment duration values.
The movement should look a little bit like a bubble rising in a glass with slow and easy left to right motion.
I tried to wrap my head around Dan’s Random Motion scripts. Maybe I’m just too tired to think straight, but I’m unable to adapt that knowledge to what I need. The frustrating part is that I believe it’s probably relatively straight forward.
Any help with this or pointing me into the right direction how I could get this to work is hugely appreciated.
Thanks a ton, everybody!
