Activity › Forums › Adobe After Effects Expressions › Randomize slider every 30 frames
  • Randomize slider every 30 frames
    Posted by Nihad Spahic on March 6, 2022 at 7:42 pm
    Hey guys, I am really stuck on this one. So I have 6 layers in the composition, 5 graphics, and one Settings layer. There is a slider control on the settings layer with rounded options from 1 to 5 with expression Math.floor(clamp(value, min=1, max=5))
    Each graphic is related to the slider on the settings layer with expression
    v = thisComp.layer(“Settings”).effect(“Select Version (1-5)”)(1);
    if (v==index-1) {100} else {0}
    so I can control visibility with slider from first to fifth element.
    I would love to randomize order on the slider, to change from 1 to 5 every 30 frames, and also to control it with the checkbox, so I could choose if I want only one layer to be shown or to randomize visibility every 30 frames.
    Cheers!
    Nihad Spahic replied 4 years, 6 months ago 2 Members · 2 Replies
  • Filip Vandueren
    March 6, 2022 at 10:39 pm
    Hello Nihad,
    maybe something like this: (expression on the slider controller)
    seedRandom(index,true);
    values=[1,2,3,4,5];
    if (effect("Random")("Checkbox").value == true) {
    i=0;
    t=timeToFrames(time/30); // change every 30 frames
    // get non repeating random numbers
    for (j=0; j<t; j++) {
    i+=1+Math.floor(random(values.length-1));
    output = values[i%values.length];
    } else {
    output = Math.floor(clamp(value, min=1, max=5));
    output;
  • Nihad Spahic
    March 7, 2022 at 12:11 pm
    Hey Filip,
    works like a charm! Thank you so much, exactly what I needed.
