Activity Forums Adobe After Effects Expressions Randomize numbers without having the same value occuring twice?
  • Randomize numbers without having the same value occuring twice?
    Posted by Mikael Holmström on June 28, 2021 at 1:57 pm
    Let’s say I have ten layers of text. By an expression I’d like to assign text of sourceText a value between 1 and 10. I want them to be randomly ordered, but never to occur twice within my 10 text later. So, the result could look something like this (layer by layer):
    [5, 3, 1, 8, 2, 9, 4, 7, 6]
    But never, for instance:
    [5, 3, 1, 1, 2, 9, 4, 7, 6]
    Is there a way to accomplish this?
    Andrei Popa replied 5 years, 2 months ago 2 Members · 1 Reply
  • Andrei Popa
    June 28, 2021 at 3:12 pm
    You can make a master layer, and add this expression to text
    function shuffle(array) {
    var currentIndex = array.length, randomIndex;
    // While there remain elements to shuffle...
    while (0 !== currentIndex) {
    // Pick a remaining element...
    randomIndex = Math.floor(Math.random() * currentIndex);
    currentIndex--;
    // And swap it with the current element.
    [array[currentIndex], array[randomIndex]] = [
    array[randomIndex], array[currentIndex]];
    return array;
    var arr = [1,2,3,4,5,6,7,8,9,10];
    "["+shuffle(arr).join(",")+"]"
    Then, to each layer add this expression. Assign firstIndex as the index of your first text layer.
    firstIndex = 2;
    val = eval(thisComp.layer("Master layer").text.sourceText)[index-firstIndex];
    val
