Activity Forums Maxon Cinema 4D Randomize Movement of Multiple Objects
  • Adam Trachtenberg
    March 3, 2016 at 4:58 am
    One way to do it, if it’s okay for the cubes to intersect, is to use a cloner with plane and random effectors. The random effector influences the clone weight so the movement isn’t too regular, while the plain effector with linear falloff causes the clones to drop into the cube shape.
    Example: 9843_cubefall.c4d.zip
  • Jim Scott
    March 3, 2016 at 5:58 pm
    Here’s another possibility also using effectors with a cloner:
    9848_fallintocube.c4d.zip
  • Arnold Cortez
    March 3, 2016 at 9:26 pm
    Thanks for the suggestions! I’ll admit that your techniques are above my level, but I’m dissecting your files and figuring it out slowly.
