Activity Forums Adobe After Effects Randomize Mask Order
  • Randomize Mask Order
    Posted by Adhish Yajnik on September 7, 2013 at 1:35 am
    I’m trying to animate the stroke of individual characters in a text block so their outlines write-on over the course of a few seconds. I’m having an easy enough time of everything, except I’d like the characters to be drawn on in a random order, not necessarily left-to-right sequentially. I’ve found that changing the order of the layer masks does the trick, but as some of these text blocks are quite large and I’ve got a mask per character, randomizing them manually is taking a little while and not truly random (i.e. part of the write-on sequence affects characters in a seemingly random order, but others still seem left-to-right).
    I was wondering if there was a script or expression to randomize the mask order in a layer or get the stroke effect to stroke randomly instead of sequentially from the top mask to the bottom.
    Adhish Yajnik replied 12 years, 8 months ago 47,920 Members · 1 Reply
  • Adhish Yajnik
    September 8, 2013 at 10:11 pm
    Well, time to learn scripting then! 🙂
