Activity › Forums › Adobe After Effects Expressions › randomize layer order script?
  • randomize layer order script?
    Posted by Alexander on May 17, 2006 at 12:59 am
    hi,
    i am looking for a script that would be capable of randomizing the layer order of a huge pile of sequenced layers in a composition. has anyone ever come acros anything similar or has a suggestion where to look for it?
    help very much appreciated since lining them up by hand is not an option 😉
    cheers,
    alexander
    Alexander replied 20 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 17, 2006 at 1:20 am
    If they’re sequenced and you re-order them, won’t that mess things up? Do you also need to resequence them?
    Dan
  • Alexander
    May 17, 2006 at 11:07 am
    hi dan,
    thanks for your reply.
    yes, that s the idea. i want to mess up the order.
    and no, don t need to reorder them.
    i ve checked out the solution discussed in the other forum using a null object and expressions. but since i d have to apply an expression to each of the layers it is not really an option (there are just to many layers).
    a
