Activity Forums Maxon Cinema 4D Randomize Deformer (Seed)
  • Randomize Deformer (Seed)
    Posted by Hirum Horkweller on January 5, 2016 at 8:12 pm
    Hello,
    I want to create a pile of circular discs, all with different contours on the x-axis. I have a deformer with a noise shader that achieves this, and if I manipulate the “Seed” value it makes the changes per-disc that I want. However, due to the sheer number of discs I need to create, I need to automate the value of this Seed field.
    Can anyone suggest a way to do this?
    I thought that perhaps using XPresso’s “Set Driver/Driven” would be good, but I just changes all the Seed values for each deformer the same, so I would still have to change the Seed values manually to achieve variation.
    Is there a way to Randomize the value of any field? That would be amazing if so!
    Here is a screenshot to give you a better idea what I’m working on:
    – H
    – H
    Hirum Horkweller replied 10 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
