Activity Forums Adobe After Effects Expressions Randomising scale between 2 values with hold
  • Randomising scale between 2 values with hold
    Posted by Mark Warner on May 14, 2015 at 3:43 pm
    I’ve search everywhere but need help!
    I have various layers that need to be scaled uniformly picking a random values between 45 and 60% over the course of the timeline. They need to hold for a certain length of time but that hold time needs to vary before jumping to another scale between 45 and 60%. Each layer needs to look different, i.e., a different seed so there’s no obvious sync between layers.
    The closest examples I’ve found have min and max hold times with min and max values and manipulate the seedRandom – but all the layers work together or smoothly animate between values.
    Can someone help?
    Mark Warner replied 11 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 14, 2015 at 5:15 pm
    Try this:
    minVal = 45;
    maxVal = 60;
    minDur = .5;
    maxDur = 1.5;
    t = inPoint;
    seedRandom(index,true);
    while (t <= time) t += random(minDur,maxDur);
    seedRandom(t,true);
    s = random(minVal,maxVal);
    [s,s]
    Dan
  • Mark Warner
    May 14, 2015 at 5:23 pm
    That’s brilliant Dan, thank you. It looks deceptively simple!!
