Activity Forums Adobe After Effects Randomised fading in grid
  • Randomised fading in grid
    Posted by Maisie MacDonald on May 15, 2025 at 9:38 pm
    Hello! I am trying to animate a grid of rectangles, with each rectangle fading in and out randomly. I have tried using fractal noise with mosaic and use it as a luma mask but each square isn’t going from 0% to 100%, is there a way to achieve this or a different way to achieve this?
    John Martin
    replied 1 year, 4 months ago
    3 Members · 6 Replies
  • John Martin
    May 15, 2025 at 11:06 pm
    yo i’m recording a custom tutorial for you, keep an eye on here and i’ll send you the solution soon!
  • John Martin
    May 15, 2025 at 11:48 pm
  • Maisie MacDonald
    May 16, 2025 at 1:46 pm
    Thanks John, I have A LOT of shapes in the grid so looking for a solution that doesn’t make them all layers, which is why I’m using repeater
  • Graham Quince
    May 20, 2025 at 10:19 am
    I think the fractal noise approach is probably best and if they are not disappearing completely, try using a Levels effect to deepen the blacks and brighten white areas.
  • John Martin
    May 20, 2025 at 2:36 pm
    gotcha. give me a hour or so and ill send you the new tutorial
  • John Martin
    May 20, 2025 at 2:54 pm
    this method allows you to use thousands of tiles without indipendent layers and the opacity goes fully from 0 and 100 and there is a perfect match between the mosaic and the shapes, hope that helps!
    https://youtu.be/yYm9F35k5uE
