  • Posted by fabio Brasiliani on August 7, 2024 at 2:31 pm
    it is possible to create an expression to make sure that an object (for example a 100 px circle) begins to duplicate itself on the screen, thus forming many even overlapping circles, and at the same time to become increasingly larger, until a final object (circle) occupies the entire screen area; all in 2 seconds
    Hector Vera replied 2 years ago 2 Members · 1 Reply
  • Hector Vera
    August 12, 2024 at 4:53 pm
    So you are looking to duplicate circles where the new one duplicated becomes much larger than the last one right? You may need a script in order to actually duplicate the layers, you can transform these properties. Here is a link that may give you an idea on what you are looking for: https://stackoverflow.com/questions/75666624/after-effects-duplicate-layer-expression
    For a tutorial to resize the lines of shapes for example, including circles, I found a tutorial that shows an example on how he duplicated the circles in after effects and I imagine in each shape layers, you can modify the scales for each of them to make it bigger than the last: https://www.youtube.com/watch?v=mlPUM2Dvq7E Hope it helps! 🙂
