Activity Forums Adobe After Effects Expressions Random X,Y Array for Lightning Source Points
  • Random X,Y Array for Lightning Source Points
    Posted by Joe Jozwowski on February 7, 2012 at 9:12 pm
    Ok Cow Gurus,
    I have a concept that may make blood shoot out your nose.
    I’m looking to create an array of pre-set X,Y coordinates (say 5-6 entries) that I would like a the built-in lightning effect to use as start and end points.
    But I would like the start and end points to randomly change from one set to the next.
    I wouldn’t care if each change would happen at a regular interval, I just want the start and end points to be different each time the expression is fired.
    – If you were me, you’d be home by now!
    Joe Jozwowski
    The Video Alchemist
    Dan Ebberts replied 14 years, 7 months ago 2 Members · 4 Replies
  • Dan Ebberts
    February 7, 2012 at 9:33 pm
    You’ll need separate expressions for start and end, but this is the basic idea:
    points = [[100,100],[200,100],[300,100],[400,100],[500,100]];
    idx = Math.floor(random(points.length));
    points[idx]
    It gets slightly more complicated if you decide you don’t really want it to change every frame, or if you want a particular start point to always go with a particular end point.
    Dan
  • Joe Jozwowski
    February 7, 2012 at 9:48 pm
    How much more complicated?
    Right now I have 6 shape layers that are on a constant wiggle so their X-Y coordinates fluctuate throughout.
    Where you have points = [[100,100],[200,100], etc]…
    Could I just use the X-Y coordinates of those shape layers, e.g.
    points = [[thisComp.layer(“Shape Layer 6”).transform.position[0],thisComp.layer(“Shape Layer 6”).transform.position[1]],[thisComp.layer(“Shape Layer 5”).transform.position[0],thisComp.layer(“Shape Layer 5”).transform.position[1]], etc.]
    If perchance that the Start and End points are the same, that I’m not worried about…
    Joe Jozwowski
    The Video Alchemist
  • Joe Jozwowski
    February 7, 2012 at 9:56 pm
    Dan,
    I just saw another post you commented on a while back dealing with a similar issue, and you suggested to add a seedRandom(index,true) into the mix.
    With that, I can just add a Slider control, with a Hold Keyframe every second and increment that “index” by whatever I want, and that would change the seedRandom value when I specify, correct?
    Joe Jozwowski
    The Video Alchemist
  • Dan Ebberts
    February 8, 2012 at 12:43 am
    I would calculate the seed based on which time interval you’re in. Here’s an example that would calculate a new seed every half second (not tested, but should be close).
    segDur = .5;
    t = time – inPoint;
    seed = Math.floor(t/segDur);
    seedRandom(seed,true);
    Dan
