  • Posted by Eric Sanderson on January 22, 2009 at 12:48 am
    I remember learning a script a long time ago that randomly generated source text to pre-determined words but i cant for the life of me remember how to do it. I basically have 10 or so different words i need duplicated and spread out all over the place,x,y and z. Ive already done a seedRandom on the position to duplicate all over the place when copied, but i dont want to have to type out in seperate layers all the different words so if someone knows the script i cant seem to remember that would be greatly appreciated.
    Michael Asgian replied 10 years, 7 months ago 6 Members · 6 Replies
  • Eric Sanderson
    January 22, 2009 at 1:01 am
    i started by keyframing my source word with all the words i want within 1 second then used this...
    seedRandom(1,true);
    text.sourceText.valueAtTime(time=random(0,1))
    ok so i figured out a way to get the result i want but im sure its not the way ive done it before and probably not the best way of going about it, so heres what i did but i would still like to know the “right” way to do it. thanks.
  • Dan Ebberts
    January 22, 2009 at 1:02 am
    This should work:
    myWords = [“one”,”two”,”three”,”four”,”five”,”six”,”seven”,”eight”,”nine”,”ten”];
    seedRandom(index,true);
    myIdx = Math.floor(random(myWords.length));
    myWords[myIdx]
    Dan
  • Paul Hennell
    January 22, 2009 at 10:29 am
    I think you might find this script useful.
    Only in after effects do children get to pick and whip their parents.
    https://hennell-online.co.uk
  • Filip Vandueren
    January 23, 2009 at 12:31 am
    seedRandom(1,true);
    random(0,1);
    I think you might be better off precomping that text-layer with the keyframes,
    enable collapse-geometries on the precomp (so they remain vector-scalabel),
    then add Time-remapping with a similar expression.
    This way, you can use different fonts, sizes, colours, or ever important kerning-adjustments etc… for the different words.
    The sourceText only copies the actual string, not any other fine-tuning settings contained in a text keyframe.
  • Greg Jones
    January 30, 2009 at 9:07 pm
    This is great. Once typing this expression in, how do you get it to animate?
    Greg Jones
    Greg Jones
    Orlando,Fl.
    https://www.d7-inc.com
  • Michael Asgian
    February 6, 2016 at 6:05 pm
    This is great!
    Is there any way to stop animating and have just one random that will value that will stay up throgh the composition?
