Activity › Forums › Adobe After Effects › random wiggle with probablility
  • random wiggle with probablility
    Posted by Accountclosedduetonorealnameused on February 13, 2007 at 3:42 pm
    I have a simple expression for random wiggle:
    seedRandom(13,true);
    wiggle(2,7)
    I would like to add code that would introduce probability, so if probability = 0 there the expression would yeild no wiggle, and if it were 100 it would wiggle all the time (yeilding the same result as the expression above)
    thanks!
  • Colin Braley
    February 13, 2007 at 4:08 pm
    Maybe something like this…I’m not sure if I know what you mean
    probability = 12;//some number from 0-100
    seedRandom(index, true);
    shouldWiggle = random(0, 100);
    if( shouldWiggle < probability ) wiggle(2,7) else value I don't hava AE at this machine but I think that should do the trick. ~Colin
  • Accountclosedduetonorealnameused
    February 14, 2007 at 4:57 pm
    Colin, this seems to turn the wiggle OFF at a probability of 71 or less and ON at a value of 72 or above, only.
    any ideas?
