Activity › Forums › AJA Video Systems › Random White Pixels
  • Random White Pixels
    Posted by Chris Anderson on September 29, 2008 at 7:47 pm
    I have a new Kona 3 in a fairly new MacPro 8 core. I’m running FCP 6.04 with the latest Leopard.
    I’m seeing random dancing white pixels when playing video thru FCP.
    I see it on my Apple Cinema Display which is fed from the K3 Box 1080i 29.97 SDI to a Blackmagic HDLINK.
    and it’s also on my CRT which is fed 525 29.97 svideo from the Kona.
    It’s not on the video in the Canvas and doesn’t appear in any Quicktime exports.
    When I output a test signal from the Kona control panel, I don’t see it but it usually takes some motion to activate the problem.
    I called AJA a few weeks back and they said to wait for this next driver which I installed today leaving the same results.
    I’m guessing it may be a hardware problem and I will call AJA again but I wanted to check if anyone else experienced this.
    Chris
    Chris Anderson replied 18 years ago 3 Members · 6 Replies
  • Jeremy Garchow
    September 29, 2008 at 10:37 pm
    Call them again.
    Jeremy
  • Eric Sternberger
    September 30, 2008 at 11:05 am
    I´m seeing this too. Both on G5 and a Mac Pro. It goes away when you shut down the computer, then reboot. A simple reboot is not enough.
    It seems to be a problem since 6.0 (I think)
  • Eric Sternberger
    September 30, 2008 at 11:07 am
    … I`m in Pal land, mainly working in 625i, we are monitoring the signal with sony broadcast crts over sdi
  • Jeremy Garchow
    September 30, 2008 at 3:06 pm
    Guys-
    Please trust me and call or write AJA support.
    Jeremy
  • Eric Sternberger
    September 30, 2008 at 3:32 pm
    [Jeremy Garchow] “Please trust me and call or write AJA support. “
    …sure I do. the last time I had a problem I got an answer from Aja just two hours later… great support 🙂
  • Chris Anderson
    September 30, 2008 at 4:28 pm
    I will definitely call them again. I have to finish this project first which fortunately is going to DVD.
    I was just curious if anyone else has experienced this and what their solution was. And to check if I was overlooking something.
    thanks
