Activity › Forums › Apple Final Cut Pro Legacy › random volume changes/peaks during playback
  • random volume changes/peaks during playback
    Posted by Lauren Gallagher on July 21, 2009 at 8:19 pm
    I’m working on a project that involves lots of audio, basically building all the audio into a real life scene. There is one constant audio track that is randomly increasing in volume during playback.
    I haven’t commanded it do to this, and I’m totally stumped as to why it keeps happening. has this ever happened to anyone else before?
    Its so fickle, it happens about every other time I play it back.
    ah!
    Any advice/suggestions are greatly appreciated!
    thanks people,
    -Lauren
    Lauren Gallagher replied 17 years, 2 months ago 3 Members · 3 Replies
  • Nicole Haddock
    July 21, 2009 at 9:22 pm
    I’ve had this happen before after doing alot of audio edits and it’s always been bad render files. The easy solution is either deleting all of your render files for that project OR copying all the media in your sequence, pasting into another, and rendering that. Theoretically, it should solve the audio problem, but a good old Preferences trashing couldn’t hurt either.
  • John Fishback
    July 21, 2009 at 9:45 pm
    You can also try an Audio Mixdown: Sequence Menu > Render Only > Mixdown.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Lauren Gallagher
    July 22, 2009 at 3:34 pm
    Doing the mixdown render worked!! thanks you guys, super helpful
