Activity › Forums › Adobe After Effects › Random to ‘right’ and messy text effects
  • Random to ‘right’ and messy text effects
    Posted by Igor Harmendani on June 11, 2012 at 6:45 pm
    Hello everyone!
    Please look at 0:23 in this video
    https://www.youtube.com/watch?v=4pdqeu9LW2c
    As you can see the text is all random but it gets “right” at some point, making it legible. Then it kind of ‘explodes’, leaving all those random letters floating in random positions.
    So, how can I replicate this effect in AE?
    PS: Sorry for my english
    Brian Charles replied 14 years, 3 months ago 4 Members · 4 Replies
  • John Cuevas
    June 11, 2012 at 7:16 pm
    You could replicate this in AE using 2 text animators. Create your paragraph of text, twirl open the text and under the animate pulldown select “Offset” Where it says “Character Offset” change the number till you get a look you like. I would change the “Character Alignment” pulldown to adjust kerning. Open the range selector and enable a “Start” keyframe of 0%, move the Time Indicator and change “Start” to 100%
    For making the text ‘explode’ at the end, I would just apply the text preset 3d Scramble in Position z and reverse the keyframes. In your example the explosion happens all at once, so if you change the first keyframe to hold keyframes, it would look like the video.
    I made quick example project to illustrate what I did. 4275_simpletextexample.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Roland R. kahlenberg
    June 11, 2012 at 7:20 pm
    This looks like two Text Layers are being used. The headline text uses the Character Offset with what looks like Hold KFs to animate the Character Offset value from a number down to zero (at 0, all characters are not offset, hence you get the characters that you typed).
    The Espresso Eye Chart Text Animation preset provides an example of the Character Offset Text Animator Property.
    The smaller text looks like a combination of Character Offset and a simple multi-line fade-in.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Igor Harmendani
    June 11, 2012 at 7:47 pm
    Thanks for the tips, guys!
    There are really useful things in AE that I still don’t know, and it’s always good to discover them!
    Thanks for the help!
  • Brian Charles
    June 11, 2012 at 8:08 pm
    Or you could use a wiggly selector and animate tracking, position and rotation.
    See: 4276_typeexplosion.aep.zip
