Activity Forums Adobe After Effects random text letter position
  • random text letter position
    Posted by Kevin Olmsted on February 13, 2014 at 10:34 pm
    Hello all!
    I don’t know if the answer to my question is a potential plug-in or expression… or just a pipe dream, so here goes…
    I want to be able to type a word, and then slightly randomize the position of each letter, specifically on the Y axis, giving it a bit more punk look or attitude.
    This is a “logo” (using that term loosely) just being built in AE CC for a spec, that’s why I’m not building in PS or AI. Plus, I can type on the letters if I want, which I’m leaning towards.
    I’m not necessarily looking to animate the letters, but if that gets me to the end result that’s fine, I can work with that.
    Short of typing each letter and manually positioning it, is there a more elegant solution to this?
    Thanks for any help you guys can offer.
    Kevin
    Kevin Olmsted replied 12 years, 7 months ago 2 Members · 2 Replies
  • George Goodman
    February 14, 2014 at 2:28 am
    This is actually really simple.
    – Create your text layer
    – Add a position animator
    – Change the Y value of the position animator to however much of a range you want the letters to vary
    – Add a wiggly selector (from the same menu as the animators) and delete the range selector
    – Turn wiggles per second to 0 (otherwise it animates)
    – If you want to see different variations, just change the number in the random seed.
    “|_ (°_0) _|”
    Sincerely,
    George
  • Kevin Olmsted
    February 14, 2014 at 2:44 am
    George, Thank you! That worked perfectly!
