Activity › Forums › Adobe After Effects › random string of 1’s and 0’s
  • Darby Edelen
    September 25, 2007 at 6:26 pm
    You should be able to do this pretty quickly with a text animator.
    Try typing out a few 0s in a text layer. Select this layer and go to Animation>Animate Text>Character Offset.
    Now, change the Character Offset property to 1 and delete the default Range Selector. Add a new Wiggly Selector (use the drop down menu to the right of “Animator 1”) and reveal this selector’s properties. Change the Min Amount property to 0% (otherwise you’ll end up with 0s, 1s and 9s) and leave all other properties the same.
    This should give you a random sequence of 0s and 1s. You can change the Wiggly Selector’s properties to have the numbers change more quickly (Wiggles/Second).
    Let me know if you need more details.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Roei Tzoref
    February 26, 2021 at 1:22 am
    here’s a code courtesy of Stephen Dixon:
    make sure you are using the JavaScript expression engine
    let digits = 9; // number of digits
    Math.round(Math.random(Math.pow(2, digits) -1)).toString(2).padStart(digits, “0”)
