Activity › Forums › Adobe After Effects Expressions › Random speed of time
Posted by Ilya Sire on March 25, 2015 at 12:13 amHi forum,
i have this T = time*effect(“Speed”)(“Slider”) to apply to substr(0,T)
but is it possible to make it random speed to T value? so it will make time slow/fast/slow randomly speed within slider range value?I read about this from https://www.motionscript.com/articles/speed-control.html this way more advance i hardly to understand.
I hope someone can help.
ThanksJason Jantzen replied 10 years, 3 months ago 3 Members · 12 Replies -
Dan Ebberts
March 25, 2015 at 4:35 pm>is this possible to do?
Probably, but I really don’t understand your question…
Dan
Ilya Sire
March 26, 2015 at 3:07 amT = time;
substr(0,T);how can i make T running randomly speed? so the letters come sometime fast or slow.
i got this similar result from your solution but this using slider to control speed. How to convert it using speed min or max value?
ilyaslider = effect("rpm")("Slider");
accum = 0;
f = timeToFrames(inPoint);
while (f < timeToFrames()){
accum += slider.valueAtTime(framesToTime(f));
f++;
accum*thisComp.frameDuration*60 //60 what is that? -
Dan Ebberts
March 26, 2015 at 6:14 amLike this maybe?
tMin = .05;
tMax = .5;
t = inPoint;
n = 0;
seedRandom(index,true);
while (t < time){
t += random(tMin,tMax);
n++;
substr(0,n)
Dan
Ilya Sire
June 10, 2015 at 8:09 pmHi Dan,
How to use this random value to linear() time?
Ilya -
Jason Jantzen
June 1, 2016 at 7:18 pmHey Dan, I’m trying to use this idea here to animate the offset of a Trim Path so that when I duplicate each instance of the path, they animate at random speeds, but putting this expression on the Offset parameter yields an error “Function substr is undefined.” Any idea how to make this work?
Jason Jantzen
vimeo.com/jasonj -
Dan Ebberts
June 1, 2016 at 7:31 pm>putting this expression on the Offset parameter yields an error “Function substr is undefined.
This is a source text expression, so it’s probably completely unsuited to what you’re doing. How are you animating the trim paths now? What range of speeds are you looking for?
Dan
Jason Jantzen
June 1, 2016 at 7:46 pmI was using this to get a random offset value with the time value. I’d like to randomize the time value somewhere between 25-35. Thanks for taking a look, Dan!
seedRandom(1,true);
random(0,360)+time*30;Jason Jantzen
vimeo.com/jasonj
