Activity Forums Adobe After Effects Expressions Random Seed with varying “Hold Time”
  • Random Seed with varying “Hold Time”
    Posted by Vladislav Macíček on March 22, 2018 at 6:35 pm
    Hey guys, could somebody help me with this?
    Basically, I have these inputs:
    maxHoldTime = 1.0 [sec];
    randomness = 0.5 [0 – 1.0];
    minHoldTime = (1 – randomness)*maxHoldTime;
    and I need to change a Random Seed value every ‘minHoldTime’ to ‘maxHoldTime’ seconds.
    Ideally in increments of 1 so the pattern doesn’t repeat. Any ideas?
    I would be grateful for anything, so thanks in advance,
    Vladislav
    Noel Powell replied 7 years, 4 months ago 3 Members · 9 Replies
  • 9 Replies
  • Dan Ebberts
    March 22, 2018 at 7:21 pm
    Play around with this and see if it helps:
    maxHoldTime = 1;
    minHoldTime = .5;
    seedRandom(index,true);
    totalTime = 0;
    while(totalTime <= time){
    holdTime = random(minHoldTime,maxHoldTime);
    totalTime += holdTime;
    holdTime
    Dan
  • Vladislav Macíček
    March 22, 2018 at 7:56 pm
    I’m not sure, I tried adding this:
    seed = Math.floor(time/holdTime);
    seedRandom(seed, true)
    but I’m probably doing something wrong…
  • Dan Ebberts
    March 22, 2018 at 7:59 pm
    Depending on what you’re planning on doing next, you could just change the last line of my expression to:
    seedRandom(holdTime,true);
    Dan
  • Vladislav Macíček
    March 22, 2018 at 8:10 pm
    I’ve got some effect with Random Seed and I want the seed to increment by 1 in the random holdTime intervals. I’ve got no idea how to do that. Also sorry for my English, it’s not my mother tongue.
  • Dan Ebberts
    March 22, 2018 at 8:41 pm
    Try it this way then:
    maxHoldTime = 1;
    minHoldTime = .5;
    totalTime = 0;
    seed = 1;
    seed++;
    seed;
    Dan
  • Vladislav Macíček
    March 22, 2018 at 8:50 pm
    Brilliant, it works exactly how I imagined. You’re just awesome!
    Vladislav
  • Noel Powell
    May 18, 2019 at 3:02 pm
    Thank you for this expression, Dan. I wonder if you might help me take it a step further. I’ve been struggling to get it to work for my purposes because I’m using the result to seed a random point in time. The problem is since Time is a continually increasing value, my random point in time is continually changing – even though the seed is not changing (at least not until the HoldTime renews).
    As you can see, I added a couple lines to the code. I have a Point Control that is moving/changing value. I need to retrieve random positions along the path that the Point Control has traveled, and I need those positions to remain still for the duration of the HoldTime. With this expression, I can get random positions along the path of the Point Control, but those positions won’t stay still – they keep traveling forward along the path. Any ideas? Thanks so much for your time.
    maxHoldTime = 1;
    minHoldTime = .5;
    totalTime = 0;
    seed = 1;
    seed++;
    seedRandom(seed,true);
    t = random(time);
    effect("targetPosition")("Point").valueAtTime(t);
    After Effects Templates – digital glitch effects, 80s VHS effects, old film effects, art effects, and more: https://CreationEffects.com
  • Dan Ebberts
    May 18, 2019 at 6:11 pm
    I’m not sure if this is what you’re after, but how about:
    t = random(totalTime);
    Dan
  • Noel Powell
    May 20, 2019 at 9:49 pm
    Thanks, Dan. That does keep my random positions static so they’re not moving anymore. I needed to retrieve random valueAtTime positions of a Point Control that was moving. The positions needed to be along the path that the moving Point Control had already traveled, which is why I used random(time). Random(totalTime) chooses some random positions from the where the point is going to be, rather than just where it’s been. But I was able to add a little more math and it seems to be working well. Sorry, I should have explained better, but thank you! I couldn’t have got it working without you.
