Activity Forums Maxon Cinema 4D Random point movement
  • Random point movement
    Posted by Mikael Aronsson on March 19, 2020 at 7:58 am
    Hi!
    In Lightwave there is a command called Jitter, you select a number of vertices on a mesh and the Jitter command will move all the points a random amount in one or more directions (amount and directions can be selected), for example to add some imperfections to a flat surface, does C4D have something that works in the same way ?
    Mikael Aronsson replied 6 years, 6 months ago 3 Members · 3 Replies
  • Jim Scott
    March 19, 2020 at 4:07 pm
    You could use a Displacer deformer, or add a Displacement channel to the surface’s material (the result of which will only be seen when rendered).
  • Brian Jones
    March 19, 2020 at 4:19 pm
    Mesh/Commands/Set Point Value (that’s where it is in R20 – I don’t have R21 at work) needs to be editable in Point mode and use the Crumple option is another option
  • Mikael Aronsson
    March 20, 2020 at 7:00 am
    Thanks, that worked very well (It’s under Mesh/Move/Set Point value in R21)
