Random Overlapping Character Scaling
This is likely a simple solution that I’m simply missing. I have a line of text and I want each letter to scale from 0% to 100% in a random order. I can easily accomplish this through text animations set to ‘per character’ animation. However, when I do so, it animates each letter one at a time, not starting the next letter scaling animation until the previous one has finished. Is there a way to overlap these character animations in a way that A) several characters can scale simultaneously based on a couple of keyframes and B) I would be able to swap out the text with alternative text later and not break the effect? Thank you!
