Activity Forums Adobe After Effects Expressions Random opacity that varies over time?
  • Random opacity that varies over time?
    Posted by Geraint Abbott on October 8, 2008 at 11:49 am
    Hey guys,
    Just a quick question – this is probably something very simple, but I can’t get my head around it at the moment.
    I have a layer that is using a the ‘random’ expression to vary it’s opacity. However, I want this random opacity to get ‘less random’ over a set time, until it reaches a point at which it is entirely visible/the opacity is locked at a defined point.
    Does that make sense?
    So basically, at frame 0, the expression will have the effect of:
    random(0,100)
    But by frame 200, the expression will have the effect of:
    random(99,100)
    Or something similar. Is there a way to do this? If possible, I need user-definable variables for the length of transition, as well as adjustable stand and end values for the random-ness. Any help would be most appreciated!
    Many thanks,
    Geraint Abbott.
    Lukasz Pason replied 16 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Eric Sanderson
    October 8, 2008 at 3:28 pm
    t = Math.exp(time)
    random(t,100)
    Try something like this..
  • Eric Sanderson
    October 8, 2008 at 3:32 pm
    t = timeToFrames(time)
    random(t,100)
    …or actually even better, this one is more literal, tacking the exact number of the frame up to 100 for the random generator.
  • Eric Sanderson
    October 8, 2008 at 3:38 pm
    t = timeToFrames(time)/2
    random(t,100)
    sorry, i just saw the part that you want it to be visible at 200 frames…so just divide the time by 2
  • Geraint Abbott
    October 8, 2008 at 5:22 pm
    That’s pretty cool! Thanks 🙂
    But what if I don’t want the end opacity to be 100%? I’ve tried altering the expression to say something like
    random(t,50)
    And that works fine up to frame 200 – but then it goes rather odd, going more than 50% transparent after that point. I suppose I could just cut the layer and have a second one set permanently at 50% transparency starting at 200 frames in… but it would be nice to keep the number of layers down! Is that possible at all?
    Cheers,
    Geraint.
  • Dan Ebberts
    October 8, 2008 at 6:30 pm
    Try changing it to this:
    t = Math.min(50,timeToFrames(time)/2);
    random(t,50)
    Dan
  • Eric Sanderson
    October 8, 2008 at 6:31 pm
    r = random(t,100)
    if(t<100){
    r
    }else{
    50}
    You can use a conditional statement(if/else)..try this.
  • Geraint Abbott
    October 12, 2008 at 7:55 pm
    Spot on!
    Thanks guys, this worked perfectly.
  • Lukasz Pason
    March 12, 2010 at 6:00 pm
    What if you want the opacity to be random but be cued not by random time but a varying number from soundkeys output?
    Motion Designer / DJ / Father
    http://www.lukaszpason.com
    http://www.krop.com/lukasz
