Activity Forums Adobe After Effects Expressions Random opacity on specific way
  • Random opacity on specific way
    Posted by Alekos Mazzolotti on April 23, 2020 at 7:21 pm
    Please, I need help with a very specific expression. I have created this screen that is going to work as part of an intro for a series of videos.
    I want to make those green squares randomly sort of flicker, by changing the value of the opacity, but it must always go from 0 to 100 or from 100 to 0, across 1 or 2 seconds, which is not what happens if I just use a regular wiggle expression on the property.
    The behavior I need is:
    – random interval (1 to 3 seconds)
    – opacity goes from 0 to 100 in 1 or 2 seconds (30 fps)
    – opacity goes back from 100 to 0 in 1 or 2 seconds
    I have done this manually, by adding certain keyframes and telling them to loopout. As there are too many, you can’t notice it’s a cycle and it gives the illusion of randomness. But I have to manually create this randomness using keyframes at different points for every layer, which can become an exhaustive processes if I intend to keep this line of work for other screens.
    I already have each green square on its own layer. Is there a way to make it more automatic through the use of an expression?
    Alekos Mazzolotti replied 6 years, 5 months ago 2 Members · 4 Replies
  • Dan Ebberts
    April 23, 2020 at 8:21 pm
    It sounds do-able, but it seems like there’s info missing. Maybe a more detailed example would help.
    Dan
  • Alekos Mazzolotti
    April 24, 2020 at 8:16 pm
    Sure!
    Here, that’s what I did manually:
    In this example, as I said, there is no real randomness, for I used keyframes and a loopout expression in a manner that created more or less the same effect.
    Can I create this behavior via expression?
  • Dan Ebberts
    April 24, 2020 at 8:53 pm
    This is a pretty simple version that might get you started:
    minFade = .1;
    maxFade = .5;
    minHold = .5;
    maxHold = 1.5;
    minDelay = 1;
    maxDelay = 1.5;
    seedRandom(index,true);
    myFade = random(minFade,maxFade);
    myHold = random(minHold,maxHold);
    myDelay = random(minDelay,maxDelay);
    myStart = random(minDelay);
    if (time > myStart){
    myPeriod = myFade*2 + myHold + myDelay;
    t =(time - myStart)%myPeriod;
    if(t < myFade)
    linear(t,0,myFade,0,100)
    else
    linear(t,myFade+myHold,myFade*2+myHold,100,0);
    }else
    0
    Dan
  • Alekos Mazzolotti
    April 25, 2020 at 6:19 pm
    Magnificent!
    It worked perfectly. Thanks a whole lot, friend!
