Activity Forums Apple Final Cut Pro Legacy Random offline clips when using FS700
  • Random offline clips when using FS700
    Posted by Facundo Campos on September 12, 2014 at 8:43 pm
    Hey there.
    Background: I am working with FCP7 on 10.6.8. As far as hard drives go, this problem has hit me on USB 2 & 3 and firewire800 drives.
    Either way, I’m working with footage that I shot on an FS700 (to the SD card) and I’m having huge problems.
    I bring in the ProRes footage with Log and Transfer on FCP7 and all works fine. I start editing without problems, but then something weird happens.
    Sometimes when I open FCP again, it says random files are missing. I check the Capture Scratch and they are in fact, not missing. They are right there. I reconnect the files, but then instead of bringing the right files, it brings in random ones.
    Say, clip 100-120 are offline, when I reconnect the files it brings in clip39-59. So the file says clip100, but it’ll be the same thing as clip39.
    Then, when I go back into the Capture Scratch, the files have literally been re-written so that clip100 is literally the same as clip39.
    What’s going on here?
    John Fishback
    replied 12 years ago
    2 Members · 1 Reply
  • John Fishback
    September 12, 2014 at 10:28 pm
    Sounds like a job for Disk Warrior. It rebuilds your disk’s directory. I use it once a month to prevent weirdness and always when weirdness strikes. IMHO, it’s the one program every Mac user should have. It’s saved me many times.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.9.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCP-X 10.1.3, Motion 5.0.7, Compressor 4.0.7
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
