  • Posted by Scott Mcgee on August 29, 2017 at 8:56 am
    I understand that there is no true, valueattime random expression.
    But I need someway, not necessarily if I click purge, but certainly different each day.
    I have random(1,6), this can’t change, but I need to think of a way to change the number each day. I’ve seen some attempts at using Date(0), but that’s to pull just a random number without worrying about the final number.
    Can anyone think of a way to create an expression that will change it’s value of the first frame using Date(0) to select a number between 1 and 6.
    Andrei Popa replied 8 years, 11 months ago 2 Members · 3 Replies
  • Andrei Popa
    August 29, 2017 at 11:32 am
    Maybe something like
    seedRandom(Date(0).split(" ")[2])
    random(1,6)
    where you use the day as the seedRandom.
    Andrei
  • Scott Mcgee
    August 29, 2017 at 2:05 pm
    That actually works quite nicely. Below is a few alterations, but if you know of a way so it doesn’t repeat the same number twice. I’ve tried a few things, but I’ve just resorted to what I’ve done below…Although I’d like to incorporate getMonth, so I can create a A*B or A+B so it’ll be different every day without repeating the same pattern each month…But unfortunately it fired back a lot of repeats and I can’t change all of them. So if there is a way to change a repeated number that would be cool…Otherwise I am very happy with this.
    Just because I want numbers 1-6, for some unknown reason it didn’t select 1 often and never selected 6. So i’ve changed it to
    D = Math.round(random(0,7));
    if(D == 0) 1
    else if (D == 7) 6
    else
    D;
    Just to be sure…I went through the course of 1-31 using a slider, it picked the same number in a row twice, so I’ve include that if the
    seedRandom(Date(0).split(” “)[2]) equals those two day, it just picks another number….
    A = Date(0).split(” “)[2];
    if (A == 5) A = 33
    else if (A ==26) A = 34
    else
    A;
    seedRandom(A,true);
    if(D == 0) 1
    else if (D == 7) 6
    else
    D;
    So thank you.
  • Andrei Popa
    August 29, 2017 at 8:38 pm
    The only way i can think of to make the seedRandom() parameter to go from 1 to 365(so you don’t have the same seed twice in a year) would be a not-so-elegant switch function in which we take all the moths and make the B equal to all the days before that month.
    switch(Date(0).split(" ")[1]){
    case "Jan":
    B = 0;
    break;
    case "Feb":
    B = 31;
    break;
    case "Mar":
    B = 59;
    break;
    case "Apr":
    B = 90;
    break;
    case "May":
    B = 120;
    break;
    case "Jun":
    B = 151;
    break;
    case "Jul":
    B =181 ;
    break;
    case "Aug":
    B = 212;
    break;
    case "Sep":
    B = 243;
    break;
    case "Oct":
    B = 273;
    break;
    case "Nov":
    B = 304;
    break;
    case "Dec":
    B = 334;
    break;
    A = Date(0).split(" ")[2]+B;
    //then the rest of your code
    I don’t have AE installed on my laptop right now so i could not test this at at all. I hope it works.
    Andrei
