Activity › Forums › Adobe After Effects Expressions › random number stable in time
  • random number stable in time
    Posted by Taha Boukhari on June 28, 2013 at 1:34 am
    hi
    im searching an expression that can help me to give to parameters a random value ( i want a value betwen to numebers for parameters to be stable in time) not like random () expression because it s change in time and i want a stable one when the i play my comp .
    Dan Ebberts
    replied 13 years, 3 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    June 28, 2013 at 4:14 am
    Just precede your random() with seedRandom() with the timeless parameter set to true like this:
    seedRandom(index,true);
    random()
    Dan
  • Taha Boukhari
    June 28, 2013 at 10:30 pm
    Thank you some much ,you save me
    but can you give me explanation a bout the seedrandom and true and index trick that you have than.
    because i now what’s mean all what you have than but i dont now whats the combination betwen them mean
  • Dan Ebberts
    June 29, 2013 at 12:05 am
    When you set the seedRandom() timeless parameter to true, random() will generate the same random numbers at each frame. I use index as the seed mostly out of habit because it’s a seed that’s unique for each layer. You could actually stick any number in there. Changing the seed changes the results you get.
    Dan
