Activity Forums Adobe After Effects random number generator expression
  • random number generator expression
    Posted by Ted Gore on February 10, 2006 at 3:20 am
    Hey, I need to generate a random number between certain values and have it stay. The random number expression does it every frame, and I can’t figure out how to make it only choose one value.
    Any suggestions? thanks
    Ted
    Seth Taylor replied 20 years, 7 months ago 2 Members · 1 Reply
  • Seth Taylor
    February 10, 2006 at 7:43 pm
    Depending on how “random” you need it to be you could use a method like the one found in this tutorial.
    https://www.trapcode.com/in_action/particular_custom.html – around 7 min 30 seconds
    In a comp – set different numbers in different keyframes and then set that comp as the layer particle. Set the Time Sampling to be Random Still Frame.
    Hope this helps – I’m a fan of your work.
