Activity Forums Adobe After Effects Expressions Random Number Counter with expression slider not pass zero
  • Random Number Counter with expression slider not pass zero
    Posted by Bert Beltran on October 28, 2013 at 6:32 pm
    I have an text layer were the source text is parent to a expression slider. The expression looks like this:
    Math.round(effect(“Slider Control”)(“Slider”)). Then I added a wiggle expression to the slider control, but my issues is that the wiggle expression sometimes runs into negative numbers and I want to set the minimum value to Zero.
    I tried this expression that came close to doing what I wanted it to do but there are times it will jump to a negative number.
    Math.min=0;
    wiggle(1,50)
    Last thing how would I create an expression so that it has a max limit number as well. So that it did not pass the number 100. So it would count random numbers from 0 to 99.
    Muchos Thank You’s
    Kevin Camp replied 12 years, 10 months ago 2 Members · 2 Replies
  • Kevin Camp
    October 28, 2013 at 6:44 pm
    Math.min() and Math.max() need two values (unless they assume zero as one value if only one value is present).
    so for your first expression you’d want something like this:
    w = wiggle(1,50);
    Math.max(0,w)
    you’d use Math.max() since you want it to return zero if w is less than zero.
    to values to a range (0-99), you’d use both Math.min() and Math.max(), and you can embed one inside the other:
    w = wiggle(1,50);
    Math.max(0,Math.min(99,w))
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    October 31, 2013 at 9:33 pm
    clamp() would also work here…
    w = wiggle(1,50);
    clamp(w,0,99)
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
