Activity Forums Adobe After Effects Expressions Random number between 0-40 which occasionaly goes into the 40-65 range.
  • Random number between 0-40 which occasionaly goes into the 40-65 range.
    Posted by David Rodriguez on April 2, 2015 at 5:06 pm
    I am animating a mockup for a wind speed reader. I am trying to get numbers to fluctuate between 0 and 40 in the manner in which wind would, in my mind it “hovers” around numbers before gusting and then coming back down. Is there a way to keyframe this and just have the numbers bounce “around” my keyframe values or is there a pure expression way to do this?
    I also need to link this expression to both an analogue speedometer animation and a solid layer which turns its visibility on when the number passes 40 and turns itself of when under 40.
    Any help would be greatly appreciated.
    David Rodriguez replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
